1996 Oldsmobile Cutlass Left Signal No Blink
OLDSMOBILE
FRANKVETMAN
I have 1996 olds cutlas 66K milage . My left directional does not blink. WHen you try to use it the light stays on solid. The lights get brighter but they don't flash. The right side works fine and so do the emergency flashers . Any ideas. Is there a flasher fuse for each side or only one for both sides?
Feb 18, 2007 at 7:37 AM
CHEVY22
  • 1,375 POSTS
one flasher for all , i would pull the bulb and check it and the socket , may be corroded , start there ,
jim
Feb 18, 2007 at 8:58 AM
LITTLERAY
Hi Frank,
I had this identical problem w/ my 92 Cutlass about a year ago (even after replacing the bulbs). Before you invest in a new switch, you may want to try taking out the hazard flasher unit from your "convenience center" under the passenger dash and putting it in place of your indicator flasher under the driver dash. Now test the blinker. This fixed my problem. Went to the parts shop, bought a new flasher and it's worked ever since.
Feb 19, 2007 at 2:15 PM
Suggested Repair
Check the left turn-signal bulb and socket for corrosion or a poor connection. There is one turn-signal flasher; swap it with the hazard flasher to test it, and replace the turn-signal flasher if blinking returns.
Conversation Summary
A 1996 Oldsmobile Cutlass has a left turn signal that stays solid and brightens but does not blink, while the right side and hazard flashers work. One reply says there is one flasher and recommends checking the bulb and socket for corrosion. Another owner with the same symptom on a 1992 Cutlass fixed it by swapping the hazard flasher with the turn-signal flasher and then installing a new flasher.
