2002 Oldsmobile Alero Click No Start
OLDSMOBILE
ABULIDO4
This Morning my 2002 Olds Alero V4 won't start. The battery is working fine but when I turn the key I hear a little click but the car won't start. Can some one help me?
Is it the Starter or the Solenoid Switch?
Is there any way I can test the Starter myself to see if that's it?
Jan 24, 2007 at 12:36 AM
  • 75,988 POSTS
Get a remote starter switch push button type-find the starter, hook it to the battery terminal of the starter and the purple wire terminal. Don't work check all your connections from the starter to the battery..
Don't use the screwdriver method.
Jan 25, 2007 at 8:59 PM
Suggested Repair
Use a push-button remote starter switch between the starter battery terminal and the purple wire terminal. If the starter does not work, check all connections from the starter to the battery. Do not jump the starter with a screwdriver.
Conversation Summary
The owner of a 2002 Oldsmobile Alero says the battery is fine, but turning the key produces only a click and the car will not start. They ask whether the starter or solenoid is at fault and how to test the starter. The expert recommends using a remote starter switch on the starter battery terminal and purple wire terminal, then checking the starter-to-battery connections if it still does not work, and warns against the screwdriver method.
