1992 Oldsmobile Achieva Knock Near Converter
OLDSMOBILE
THADIZZLE
I have a 1992 Oldsmobile Achieva 4 door with the front engine pulley going out. It is making a nocking sound around or at the the converter. I am told this buy the guy who fixed the transmition a week ago. I thought he was the one who had done it but it seems not. I would like to know what a front Engine pulley is and what would happen if I drove the car to onother lot to be fixed and how much they usually cost to repair it if I was to do it myself. The car has around 240000 miles on it but has a rebiult V6.
Oct 25, 2007 at 9:35 PM
  • 75,988 POSTS
The front pulley also called the crankshaft pulley is a mile long away from the catalytic converter. Why don't you get underneath and check it, it might be the exhaust pipe knocking into the frame or whatever/loose hanger etc.
Oct 25, 2007 at 9:47 PM
Suggested Repair
Inspect underneath near the catalytic converter for an exhaust pipe contacting the frame or a loose exhaust hanger. The front engine pulley, also called the crankshaft pulley, is far from the converter and is unlikely to cause that knock.
Conversation Summary
The owner of a 1992 Oldsmobile Achieva with a rebuilt V6 and about 240,000 miles was told the front engine pulley was failing and causing a knock near the catalytic converter. They asked what the pulley is, whether the car could be driven to another shop, and the typical DIY repair cost. The expert explained that the crankshaft pulley is far from the converter and recommended checking underneath for an exhaust pipe hitting the frame or a loose hanger.
