2000 Oldsmobile Alero Heater Gas Smell
OLDSMOBILE
RACHEL0628
I have an automatic 2000 Oldsmobile Alero with a V6 engine. Everytime I turn on my heater I smell raw gasoline. After my car heats up the smell goes away. I looked under the engine and could not see a leak. I also could not smell gasoline coming from the engine. I do not know much about cars and I am worried it is a huge risk for me to be drinving. Your help is greatly appreciated.
Thanks Rachel
Oct 17, 2007 at 9:01 AM
CHEVY22
  • 1,375 POSTS
hey Rachel
if you pop the hood , look directly at the engine , look for fuel lines , they will lead you to a small canister with a vacuum hose on it called a regulator , get some help and have the other person turn the key to the run . not start postion and see if you can see fuel running from the regulator , the pump will only run for 2-3 seconds like this so you may have top do it several times , and you have to look close because fuel evaporates quickly especially when its hot like on the engine
let me know
jim
Oct 18, 2007 at 8:46 AM
Suggested Repair
Inspect the fuel pressure regulator and nearby fuel lines for a leak. With the hood open, have a helper turn the key to run (not start) so the pump primes for a few seconds, and watch closely for fuel coming from the regulator. Repeat as needed because fuel evaporates quickly, especially on a hot engine.
Conversation Summary
The owner of a 2000 Oldsmobile Alero with a V6 smells raw gasoline when the heater is first turned on; the smell goes away after the car warms up. No leak was visible under the engine and no gasoline smell was noted there. The expert advised tracing the fuel lines to the pressure regulator and watching it while a helper cycles the key to run so the pump primes briefly.
