2000 Oldsmobile Alero Turn Signals Fast
OLDSMOBILE
MIGUELC
2000 olds alero 100000 miles. Where is the flasher located in this car my turn signals are going crazy.
Dec 20, 2006 at 12:07 PM
BOOTDOG
  • 665 POSTS
it should be up underneath the dash on the left side. what do you mean there going crazy? like it's blinking fast? if it is then that means you have a blown turn signal bulb. have someone check your lights while you opperate them. good luck :)
Dec 20, 2006 at 12:24 PM
Suggested Repair
If the turn signals blink fast, check for a blown turn signal bulb while someone operates the lights. The flasher is under the dash on the left side.
Conversation Summary
The owner of a 2000 Oldsmobile Alero asked where the turn-signal flasher is located because the signals were acting erratically. The expert said the flasher is under the dash on the left side and that fast blinking usually indicates a blown turn-signal bulb, which should be checked while the lights are operated.
