1999 Oldsmobile Intrigue Overheat
OLDSMOBILE
BISHOPSBOO27
I have a 1999 oldsmobile intrigue 3.5 engine. There is a rattling sound that I think is coming from my water pump. My car overheated on me at 60mph and instead of stopping I continued to drive it approximately 2.5mls before I could pull it over and park it. I am going to attemp replacement myself. All I have going for me is the ability to read a Chiltons manual. I am financially unable to pay a mechanic. Should I attemp this and is there anything I should know before I proceed?
Feb 10, 2007 at 1:57 PM
  • 75,988 POSTS
Is the engine locked-up? Get a short piece of hose and start it and listen for the same noise at the water pump area. Is it there.
Remove the thermostat and observe whether its running hot.
Check the oil if its mixed with coolant or oil in coolant.
Feb 10, 2007 at 7:55 PM
BISHOPSBOO27
there is no coolant in the oil and a somebody showed me where the water pump is and the sound is coming from there. Should I attemp to replace it myself? The engine has not locked up. I can still start it.
Feb 11, 2007 at 5:23 AM
  • 75,988 POSTS
Go for it-just mark or take a pic the stuff that might be complicated to put back together. Put your 100% devotion to it-don't panic-its a piece of cake. Heck, if I was there I'll supervixe and have few while you go at it.
Note: I don't believe on Permatex sealant-its cleaniness with a gasket.
Good Luck!
Feb 11, 2007 at 6:50 AM
  • 75,988 POSTS
Go for it-just mark or take a pic the stuff that might be complicated to put back together. Put your 100% devotion to it-don't panic-its a piece of cake. Take your time. Heck, if I was there I'll supervixe and have a few while you go at it.
Note: I don't believe on Permatex sealant-its mating surfaces cleaniness with a gasket.
Good Luck!
Feb 11, 2007 at 6:52 AM
Suggested Repair
Since the engine still starts and the rattle is at the water pump, a careful DIY water pump replacement is reasonable. Photograph or mark parts before removal, take your time, and install the gasket on thoroughly clean mating surfaces rather than relying on sealant. Also confirm the cooling system is not still running hot and that oil and coolant are not mixing.
Conversation Summary
The owner of a 1999 Oldsmobile Intrigue with a 3.5 engine continued driving about 2.5 miles after it overheated and heard a rattle believed to come from the water pump. The engine still starts, and there is no coolant in the oil. The expert advised confirming the noise and cooling issue, then proceeding carefully with the replacement while marking complicated parts and using a clean gasket.
