olds intrigue, 2001 98,000 3.5
had head gaskets replaced, thermostat replaced, radiator replaced, had heater core flushed, now car over heats with standard thermostat. mechanic drilled a small hole in the thermostat now car runs to cold. does not reach the quarter mark on heat gauge. CAN YOU PLEASE TELL ME WHY THE MECHINAC DRILLED A HOLE INTO THE THERMOSTAT ? AND WHY THE CAR IS NOT PUTTING OUT HEAT? water pump was checked but not replaced.
thank you hope to hear from u soon
frisky
frisky
Jan 19, 2007 at 8:04 AM
