1996 Oldsmobile Cutlass Ciera Stalls
1996 OLDSMOBILE
HIYOUDIDYOUMISSME
  • 7 POSTS
[color=green:08b378adb8] 96 Oldsmobile Cutlass Cierra Car has 125,000 miles. Engine has 70,000 miles on it. It has a V6.[/color:08b378adb8]
Nov 2nd, 2006 I woke up and went to start my car and it would turn over and die after idleing for 10 seconds. If I put my foot on the gas to catch it to keep it running it would die right then and there. I took it to a shop and they couldn't figure it out :evil:
With all hope lost, I started looking to buy a new car.
Two weeks went by. It was now the 18th of Nov. I had about had it. I couldn't find a car nor did mine work. So I said to my friends. "Well I'm going for a drive" they all laughed. I went out and started my car right up! :shock: Of course I was happy. And noone could tell me what had happened. So I drove my car everyday after that with out trouble.
Its Dec 8th 2006 now. And it did it again. I was coming home from work and everytime I turned on a different street the car would just shut off. I'd throw it in N and it would start right back up. 7 times before I got home it did this. Now that it got me home it won't even start.
[color=red:08b378adb8]So can anyone out there help me with this? Whats going on with the car? [/color:08b378adb8]
It has a full tank of gas. It had a full tune-up a year ago. I need an oil change (I'm over 100 miles). Everyone that looked at it said it was good.
Dec 8, 2006 at 2:08 PM
MATHIASO
  • 1,209 POSTS
Check you catalytic converter.
A plugged converter or any exhaust restriction can cause the engine to stall after starting(if totally blocked), loss of power at high speeds,
check that but it could be something else...
Dec 29, 2006 at 11:16 AM
Suggested Repair
Check the catalytic converter and exhaust system for a restriction. A plugged converter can cause stalling shortly after startup and loss of power, though other causes remain possible.
Conversation Summary
A 1996 Oldsmobile Cutlass Ciera with a V6 starts, idles briefly, then dies, and applying throttle makes it stall immediately. A shop found nothing wrong. It later ran normally, then stalled repeatedly while driving and would restart in neutral before failing to start. The owner reports a full tank and a tune-up about a year earlier. The expert suggests checking for a plugged catalytic converter or other exhaust restriction, while noting another cause is possible.
