1999 Oldsmobile Cutlass Brakes Shatter
OLDSMOBILE
INGE
what causes brake shattering?
i have a '99 olds cuttlass and had the brakes fixed about 1 1/2 years ago. when i have to step on the brakes at 50+mph, they shatter. there is no squeaking, just a shattering.
thanks for your help
Apr 17, 2007 at 7:28 AM
SERVICE WRITER
  • 9,123 POSTS
The brake rotors can't handle the heat and warp when braking at high speeds. They need replacement, not machining, and should certainly replace the pads...again. Clean and adjust the rear brakes at the same time to keep the braking more equal.
Apr 17, 2007 at 3:24 PM
Suggested Repair
Replace the brake rotors rather than machining them, and replace the pads again. Clean and adjust the rear brakes so braking stays more even.
Conversation Summary
A 1999 Oldsmobile Cutlass owner said the brakes shatter when applied at 50 mph or more, with no squeaking, about a year and a half after a brake repair. The expert said the rotors cannot handle the heat and warp during high-speed braking. They recommended replacing the rotors and pads, not machining the rotors, and cleaning and adjusting the rear brakes.
