Oldsmobile Brake Grinding and Hissing
OLDSMOBILE
THINTHIN
When I apply the brakes I feel a grinding sensatiion and I hear a hissing sound coming from uderneath the car,and the car keeps moving a few seconds after the brakes have been applied.Is this just brake trouble,or could it also be transmission problems?
Jul 24, 2007 at 11:43 PM
CLY
  • 308 POSTS
Inspecting the brakes sounds like a good place to start.
Cly
Jul 25, 2007 at 12:06 AM
  • 75,988 POSTS
[quote:a9c48cca9f="thinthin"]When I apply the brakes I feel a grinding sensatiion and I hear a hissing sound coming from uderneath the car,and the car keeps moving a few seconds after the brakes have been applied.Is this just brake trouble,or could it also be transmission problems?
Thank you.[/quote:a9c48cca9f]
The wear indicator is rubbing against the rotor that's the noise you're hearing-you need new brake pads upfront/both.
Jul 25, 2007 at 12:09 AM
Suggested Repair
Inspect the brakes first. The grinding is consistent with a pad wear indicator contacting the rotor; replace the front brake pads on both sides and inspect the rotors.
Conversation Summary
The owner reports a grinding sensation, a hiss from underneath, and continued movement for a few seconds after braking, and asks whether the cause could be the brakes or the transmission. Experts recommend starting with a brake inspection and replacing the front pads because the wear indicator is likely rubbing the rotor.
