I cahnged the calipers on my 1989 cutlass supreme international.The right side bled ok.Left side fluid not coming out not bleeding.Its not ABS
Jul 3, 2007 at 5:43 AM
Check for fluid and pressure at the left caliper hose, at the hose-to-line connection, and at the master cylinder secondary (front) port, which may indicate a secondary piston problem. Also remove the left bleeder; if fluid flows, clear the bleeder with wire, reinstall it, and bleed both sides again.
After caliper replacement on a 1989 Oldsmobile Cutlass Supreme without ABS, the right side bled normally but no fluid came from the left. Replies suggest checking pressure at the hose, line, and master cylinder secondary port for a possible secondary piston issue, and clearing a clogged left bleeder before rebleeding both sides.
