Brake bleeding problem
OLDSMOBILE
JCHAS64651
I cahnged the calipers on my 1989 cutlass supreme international.The right side bled ok.Left side fluid not coming out not bleeding.Its not ABS
Jul 3, 2007 at 5:43 AM
1934FORD
  • 6 POSTS
[quote:0d1d2f1f6b="jchas64651"]I cahnged the calipers on my 1989 cutlass supreme international.The right side bled ok.Left side fluid not coming out not bleeding.Its not ABS[/quote:0d1d2f1f6b]
Jul 20, 2007 at 3:13 AM
1934FORD
  • 6 POSTS
[quote:184b072e56="jchas64651"]I cahnged the calipers on my 1989 cutlass supreme international.The right side bled ok.Left side fluid not coming out not bleeding.Its not ABS[/quote:184b072e56]
Couple things I would check.
Is there any fluid/pressure at the brake hose connection to the caliper? Is there any fluid/pressure at the brake hose connection and the brake line connection? Is there any fluid/pressure coming out of the Master cylinder secondary port. This would be the brake line that connect to the front of the master cylinder. It is possible that you have a secondary piston issue in the master cylinder.
Jul 20, 2007 at 3:17 AM
ROCKWOOD84
  • 103 POSTS
could be a stopped up bleeder.take the bleeder out of the caliper on the left side and see if the fluid will come out with bleeder out if it will take a piece of wire and unstop the bleeder and put it back in. then re bleed both sides.
Jul 22, 2007 at 9:08 AM
