1994 Oldsmobile Cutlass Cruiser AC Not Cold
OLDSMOBILE
MOSTLE
1994 Oldsmobile Cutlass Cruiser, 165,000, engine size is 3100 SFI V6 3.1 liters...this car runs like new and is in excellent condition.
The AC is not producing "cold" air as it use to. This AC is only about 5 years old, I have had it recharged once by the dealer. Do you think a loose belt can cause this or is it the Freon being low?
Today the outside temp was over 90 degrees and it never reached what I would consider cool even after driving 25 miles. :oops:
Jul 10, 2007 at 7:11 AM
SERVICE WRITER
  • 9,123 POSTS
I would say no on the belt. The freon is likley low, but is it normal or is it from a leak. I would start with a re-charge ( or conversion to r-134a) if it is r-12.
Jul 10, 2007 at 8:02 AM
Suggested Repair
A loose belt is unlikely. Recharge the A/C refrigerant, or convert the system to R-134a if it still uses R-12. Low refrigerant may be from a leak, so check for leaks if cooling does not hold.
Conversation Summary
The owner of a 1994 Oldsmobile Cutlass Cruiser says the A/C no longer blows cold air, even after a long drive in temperatures over 90 degrees. The system was recharged once about five years earlier. The expert says a loose belt is unlikely and low refrigerant is more likely, possibly from a leak, and recommends a recharge or conversion to R-134a if the system uses R-12.
