1995 Oldsmobile Cutlass High Oil Level
1995 OLDSMOBILE
FOLTS
I have a 95 olds cutlass, 3.1 litre with about 110,000 miles. It was sitting for about 8 months. It started fine but while the car was running i checked the oil dip stick and the level was almost at the top of the stick. I know the oil level was normal before I put it out to sit for awhile. I was wondering what this could mean.
May 20, 2007 at 2:30 AM
SERVICE WRITER
  • 9,123 POSTS
Is there anything unusual other than the level?
How long did you run it? It may have just been from a complete drain down that wouldn't normally happen over a real short time is my guess if it looks and smells normal.
I would drain it and replace it before getting it back going again anyways.
May 20, 2007 at 2:36 AM
FOLTS
I response to the answer I was just given. The car ran for about five minutes or so. The oil looked fine and smelled fine. There was nothing else unusual about it. The oil light never came on either. I started it twice for about 5 minutes both times and it was the same for both times.
May 20, 2007 at 2:44 AM
Suggested Repair
Drain and replace the engine oil before returning the car to regular use. If the oil looks and smells normal, the high dipstick reading after a short run may be from oil that fully drained back into the pan during long storage.
Conversation Summary
The owner of a 1995 Oldsmobile Cutlass 3.1L that sat for about eight months found the oil nearly at the top of the dipstick after running it for about five minutes, although the level had been normal before storage. The oil looked and smelled normal, there were no other unusual symptoms, and the oil light did not come on. The expert suggested the reading may reflect complete drain-back after long sitting and advised draining and replacing the oil before driving the car regularly again.
