My 95 Olds Achieva Tach goes from 6 o'clock position to just below 0 rpms after ignition. I just changed the plugs but not the wires. I'm pretty sure it worked before the change. Also, the battery (-) neg cable came a little loose but has been tightened. When turned off the tach needle returns to 6 o'clock. Did I knock something loose when changing plugs? I don't know what to check. Thanks.
SPONSORED LINKS
Tuesday, June 26th, 2007 AT 10:38 PM
