88Olds Toronado coil pack problem?
1988 OLDSMOBILE
BROCDENAWAY
Hi everyone, I'm new here but I heard this was a great forum, so I'm looking forward to your help :)
I have an 88 Olds Toronado (3.8L V6) that is only running on 5 cylinders. Five of the Six posts for the spark plug wires seem to be giving a good spark but the sixth, which is the top left one, seems to be giving no spark. I have made sure that the spark plug works and that the spark plug wire is working but I still get no spark. Does this mean that I need a new coil pack? A new ignition module? I do know that there are 2 or 3 sensors that also control this operation that could also need to be replaced but I am not sure what to do, any input would be appreciated..thank you.
( sorry if any of my terminology is wrong or silly, i don't know too much about cars :) )
May 8, 2006 at 5:08 AM
IMPORTBASHER89
  • 29 POSTS
most likely yes these coils are everywhere try a used one it dosent cost much and instalation is although in some cases tight but straight forward
May 8, 2006 at 9:53 AM
BROCDENAWAY
well I've done some testing, I'm thinking that it's not the coil pack. I hooked up a test light to each of the connections leading to the coil pack. With someone helping me I cranked the motor and each connection gave me a quick blinking light, except the one that doesn't give a spark, which gave me a real slow blinking, (different from the others). Leading me to think that it is something telling the coil pack not to fire correctly..... hmmm damn cars.
Whatddya think?
May 9, 2006 at 7:38 AM
BROCDENAWAY
I still don't know what is going on guys, I still cannot figure this out. Thinking of replacing the ignition module but that is a steep 250 bux, the module depends on two sensors I believe, one of which is very hard to replace correctly I guess. Can anyone tell me the type of computer my car has, It's got to have one, probably an OB-1 or OD-1 whatever you call it. Any input would be appreciated, thank you.
Broc :(
May 10, 2006 at 8:15 PM
IMPORTBASHER89
  • 29 POSTS
try switching the coil packs to see if the problem follows the coil
May 25, 2006 at 1:15 AM
