2002 Oldsmobile Alero Humming Noise
The hum may be a wheel bearing going bad, does it change if you steer to the left or to the right?
If those spark plugs are original, I get those changed. But not untl the first two problems are resolved.
These problems only started after I took my car into the shop to get brakes. Could it be that they messed something up?
Suggested Repair
After driving, compare wheel temperatures for a dragging brake that could reduce fuel economy. Because the hum changes with steering, inspect and replace the failing wheel bearing assembly, preferably with a Timken unit. Change original spark plugs only after those issues are resolved.
Conversation Summary
The owner of a 2002 Oldsmobile Alero reported a speed-related humming noise and a drop from about 28 to 20 mpg after a transmission flush, fuel-filter replacement, and brake service. New tires did not help. The noise became louder with slight vibration when steering right and produced a faint high-pitched sound when turning left at higher speed. The expert recommended checking the wheels for excess heat from a dragging brake, diagnosing a wheel bearing, and using a Timken bearing assembly; original spark plugs were suggested only afterward.
