2000 Other Oldsmobile Models HELP
2000 OLDSMOBILE
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
VWR
My Olds Intrigue shakes between to speeds of 30-40 badly. When I mash the gas panel it shakes and when I let off the gas panel it doesn't shake that bad. I just had the transmission rebuild and it did not shake before that (could taking the transmission in and out to rebuild have caused the shake and if so what do you think caused it.) Since then I have had the tie rods, bearing/seals, tires, replaced and it still shakes . Please help ......tanya
Aug 15, 2008 at 8:35 AM
MASTERTECHTIM
  • 4,750 POSTS
are you sure its not a engine skip? try removing plug wires on the coil towers one at a time and see if there is any corrosion. very common.
Aug 15, 2008 at 8:47 AM
VWR
I'm sure it's not the plugs. It feels like the wheels are wobbling and shaking but I have had the replaced.
Aug 18, 2008 at 12:07 AM
