1999 Mitsubishi Eclipse Power Window
1999 OLDSMOBILE
KBEUCKE
  • 78 POSTS
My drivers side power window stopped working. Got out my manual to check things out. It said to hook the motor straight to the battery to check it. Reverse the wires and check again. The diagram in my manual shows two wires, however I have 8 or more wires going to my motor. Any idea which one of these wires I need to use to check if it is working? Also my manual has nothing on replacing the motor. How is it removed? How many bolts holds it in place and what is the trick to getting it out?
May 1, 2007 at 12:40 PM
2CARPRO JACK
  • 11,533 POSTS
Most of those go to what I would guess to be an (auto-down) feature. If you remove the door panel there should only be two wires plugged into the motor.The window has to be removed from the regulator and secured up out of the way.Most reg's are held in the door with pop-rivets, they will have to be drilled out. The motor can then be removed from the reg. Sometimes they too are held on with pop-rivets. Be careful with the reg, Im not sure about that one , but some have a spring. If so secure it in a vise so it doesnt jump when the motor is removed
May 2, 2007 at 1:23 AM
Suggested Repair
Remove the door panel and test the motor using the two wires plugged into it; the extra wires are likely for the auto-down feature. Unbolt the window from the regulator and secure it up, then drill out the pop-rivets holding the regulator and motor. Watch for a regulator spring and clamp the regulator in a vise before removing the motor so it cannot jump.
Conversation Summary
The owner of a 1999 Eclipse RS reported a dead driver-side power window and asked which of the many motor wires to use for a battery test and how to remove the motor. The expert said most wires serve an auto-down feature and that only two wires plug into the motor once the door panel is removed. The window must be detached from the regulator and secured up; the regulator and sometimes the motor are held by pop-rivets that must be drilled out. A possible regulator spring should be secured in a vise before the motor is removed.
