1998 Other Oldsmobile Models 1 Radiator fan won't work
1998 OLDSMOBILE
150,000 MILES • 6 CYL • FWD • AUTOMATIC
PHIL1218
I have a 1998 Oldsmobile Intrigue with 2 cooling fans. One works fine, it comes on when the temp gauge gets to the half way mark. The other one does not, I changed the 30 amp fuse and the relay but still no fan. I used a scanner and the code that comes up was P1652. If you have any tips for me fix my problem I would appreciate it. Thanks
Mar 30, 2008 at 4:18 AM
GM code 1652 relates to cooling fan no.2
Direct power to the light blue wire at the cooling fan no.2 connector and ground -did it come On? if so and you have change the relay for fan no.2
Check the computer low and high speed control circuit-
Mar 30, 2008 at 5:47 PM
