Fan will work when car or engine get hot
if you dont have an overheating problem you shouldnt be checking any fan s
if the car isnt getting any heat and the upper hose is cold check thermostate and replace also if its overheating and the upper hose cold replace the thermostate and check coolant
you should have some relay s under hood on the pass side
SPONSORED LINKS
Monday, November 19th, 2007 AT 6:28 PM
