1998 Oldsmobile Intrigue Fuel injectors
1998 OLDSMOBILE
JLIL
After driving my car for about 7 hours straght.. I had got to my distnation and turned it off.. About 30 minutes later i went to turn it on and the engine started shaking like it is runnig out of gas n the check enigine light started blinking... I had the car for a month and it has 132,000 miles.. I got the spark plugs n wires changed.. The mechanic says that i need ALL 6 fuel injectors replaced... COuld i just put fuel injector cleaner in it to fix the injectors??
Jan 20, 2006 at 9:31 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
If adding a follow-up, state whether the improvement continued and include any diagnostic findings already documented by the shop.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
JPTRUAX
  • 18 POSTS
It is not very comon that all 6 injectors go bad at the same time! I would have someone put it on a computer and that should tell you exactly what it is. Maybe 1 or 2 injectors but not 6. The ones that are not bad should be cleaned. Fuel injector cleaner will not fix injectors.
Jan 21, 2006 at 1:53 PM
JLIL
Thanks man, i went and got em cleaned and it fixed all of em.. They were just dirty , now my car runs like new.. You saved me a lot of money... THANKS AGAIN!!!
Jan 23, 2006 at 4:58 PM
Discussion summary
The owner of a 1998 Oldsmobile Intrigue reported engine shaking and a blinking check-engine light after restarting following a long drive. Spark plugs and wires had been changed, and a mechanic recommended replacing all six fuel injectors. The owner later reported that injector cleaning resolved the problem.
Reported outcome: The owner reported that cleaning the injectors fixed the problem and that the car ran like new.
This is an owner-reported result. No diagnostic codes or shop findings were supplied to explain the original replacement recommendation. The thread does not establish that injector cleaning would resolve similar symptoms on another vehicle.
Read the original discussion
