1997 Other Oldsmobile Models oi pump
1997 OLDSMOBILE
FUNGIRL7307
Engine Mechanical problem
1997 Other Oldsmobile Models 4 cyl Front Wheel Drive Automatic
why does my 1997 oldsmobile achieva blow the oil filter when I put the correct amount of oil in it and it blows the seal around it. I have had it to a few mechanics in my area and they had no idea.
Jul 9, 2008 at 4:09 PM
  • CAR REPAIR CONTRIBUTOR
Test the oil pressure to finger the oil pump
As oil pressure builds in the oil system, it exerts pressure. A spring-loaded "pressure relief valve" built into the oil pump (or near the pump) opens when pressure exceeds a certain limit (typically 50 to 60 psi) and either reroutes oil back into the pump's inlet or the oil pan. This prevents a dangerous buildup of pressure that could rupture the oil filter or blow out press-fit oil plugs.
Good Luck
Jul 9, 2008 at 4:35 PM
