1994 Other Oldsmobile Models Noise around harmonic balancer
1994 OLDSMOBILE
193,000 MILES • 6 CYL • FWD • AUTOMATIC
JPHESS
My daughter's 1994 Olds 88 LSS has a 3800 in it. It has a rattling, not a knocking, right around the harmonic balancer pulley. It is louder at idle than it is when the gas is given and RPM's increase. The rattling is pretty loud. I lowered the oil pan and rotated the crank and everything looked fine. The timing chain had some play in it, but I don't know how much play that it really should have. I don't know if anything but the chain could be rattling like this. I was going to take the timing chain cover off, but I cannot remove the harmonic balanced bolt in the crank. A cheater bar and a 3 foot pipe would not budge it. Any hints on what the rattling is on a best guess and how to bust the bolt loose? Thanks!
Jesse
Apr 11, 2008 at 9:52 AM
NDDUNC
  • 47 POSTS
sounds like the balancer is bad. its made of a rubber like materal that deteriates.it will come off with an air wrench.after the bolt comes out , you may need a pulley puller.[rent at parts house] if ive helped or can help some more please reply back!dunc
Apr 19, 2008 at 4:55 PM
