1987 Other Oldsmobile Models harmonic balancer
1987 OLDSMOBILE
112,875 MILES • 6 CYL • FWD • AUTOMATIC
DDR1016
i need help how do i remove the harmonic balancer? without using a special tool.
May 8, 2008 at 8:12 AM
MERLIN2021
  • 17,250 POSTS
You may try, but you will never get it off without a puller! Autozone will rent then refund the rental fee, get the tool!
May 8, 2008 at 8:40 AM
Either you drop the starter and jam the flexplate or use a long breaker bar brace it properly underneath-clear out of the way and crank engine over this will loosen it-or you can try an impact wrench-
Watch out for the Crank sensor if it has one-
May 8, 2008 at 8:41 AM
