1994 Other Oldsmobile Models
BROWN SUGGA 1963
  • 1994 OLDSMOBILE
  • 6 CYL
  • 100,000 MILES
My car is a 1994 98 oldsmobile that runs perfect for about 15 minutes then it shuts off and will not start up just turn over. My mechanic has replaced the coil pack, brain box, crank sensor and still it does the same thing. Can you make some suggestions to help my mechanic who is stumped.
Sunday, August 24th, 2008 AT 8:22 PM
  • 31,937 POSTS
Hi there,
You will need to check for spark, injection pulse and fuel flow when it won't start, this will be the best way to start to track down your problem also have a scan done to check for any set fault codes, as this will also help point you in the correct direction, start here.
Mark (mhpautos)
Sunday, August 24th, 2008 AT 11:30 PM
