1993 Other Oldsmobile Models fuel pumps
1993 OLDSMOBILE
M1CHAEL
Engine Performance problem
1993 Other Oldsmobile Models Two Wheel Drive Automatic 312200 miles
it's actually a 1993 oldsmobile cutlass supreme sl with a 3.1 engine. I replaced the 2 fuel pumps and it still will not run. I noticed there is no fire to the fuel pump. What do you recomend?
Dec 29, 2009 at 4:44 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd check the voltage circuits at the fuel pump relay, use a digital multimeter. The relay should be in the underhood electrical center. Also, there should be a fuel pump test connector, close to battery, red wire with electrical connector, nothing plugged into it. If you use a jumper wire, with inline fuse, from battery voltage to connector, the pump should run, no need to use the key.
Dec 29, 2009 at 5:13 AM
