1993 Other Oldsmobile Models Brake Master Cylinder
1993 OLDSMOBILE
168,000 MILES • 6 CYL • AWD • MANUAL
CORDOVAGRAY
Hello, I have an 93 Olds Eighty-eight, which has a leak where the Brake master cylinder connects to another part(actually, where the bolts connect). Is there a gasket that might need replacing, or am I looking at replacing the whole master cylinder. Any help would be useful!
Sep 22, 2008 at 8:16 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:63793cb6a5="cordovagray"]Brakes problem
1993 Other Oldsmobile Models 6 cyl All Wheel Drive Manual 168000 miles
Hello, I have an 93 Olds Eighty-eight, which has a leak where the Brake master cylinder connects to another part(actually, where the bolts connect). Is there a gasket that might need replacing, or am I looking at replacing the whole master cylinder. Any help would be useful![/quote:63793cb6a5]
If the is brake fluid leaking there then you will need to replace the Master Cylinder. what you are refering to as far as being bolted to is the Power Brake Booster. The booster is a vacuum chamber and brake fluid shouldn't be leaking into it. It will damage it and you will have to replace both.
Sep 22, 2008 at 8:47 AM
