1989 Other Oldsmobile Models Oldsmobile cutlass ciera not sh
1989 OLDSMOBILE
175,000 MILES • 6 CYL • FWD • AUTOMATIC
BEAVISANDBUTTHEAD
There's something unusual going on with my 1989 olds cutlass ciera. It only shifts at the redline. The transmission acts as if the pedal is constantly at full throttle, even though it's not. If I floor it when the car is in 2nd gear at low speed, the tranny does not go back down to first. It just stays in second. Once I slow down enough, it goes back to first gear.
so heres the summary: the tranny only shifts at the redline. it goes to 2nd at 45 mph, and 3rd at 85 mph, and it doesn't go fast enough to even get near the redline in 3rd gear, so it won't go into 4th. when i do a kickdown to attemtp to get it to shift into a lower gear, it doesnt do it.
My theory: Either a throttle position sensor or a engine vacuum sensor has gone awry, because i've heard that the ECU uses one or the other to determine when to make the tranny shift.
May 25, 2008 at 3:16 PM
LEGITIMATE007
  • 5,121 POSTS
yes that is the first thing your gonna want to check. the tps. also make sure all of your vacuum lines are in good shape,no cracks, unhooked etc. remember the tps is potentionmeter which means that while testing it, it will have to slowly be turned. thats how the voltage is sent to the computer and it knows where your foot is on the pedal. by the different volatage it creates when the throttle plate is turned.
May 26, 2008 at 2:40 AM
