I have a 1986 Olds with a 2.5L TBI. If I trickle in fuel, car will start and continue to run as long as fuel is poured in. Fuel pump pressure is correct. There is 12 volts to the red wire at the injector. If I hotwire the injector it sprays and the car will run. The injector draws about 6.5 amps. The check engine light will not come on with the ignition switch on. The check engine light will not flash any codes. The EMC fuse is good. Is the EMC bad? Is the injector load too high? Any help would be good! Thanks in advance.
Mar 16, 2007 at 2:49 PM
