1982 Oldsmobile Delta 88
1982 OLDSMOBILE
CAROLINE8
My 1982 Oldsmobile Delta 88 shuts off every time I let my foot off the gas.This has only been happening for the past few days. I just changed the battery, starter, oil filter,fuel filter, and the fuel pump..I dont know what else to change..PLEASE hELP..
Aug 20, 2007 at 2:31 PM
CHARMED21382
I have the same car, 82 delta 88, i had to turn up the idle on the carb to give it a higher idle. ( sometimes the vibration cause the screw to loosen up) clean the carb, spray cleaner in there. cause my car use to stall now its running fine. Mine has the 307 V8 version in it. Hope that helps.
Oct 17, 2007 at 2:33 PM
