2001 Oldsmobile Intrigue stalling when hot
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
CADDY47
  • 5 POSTS
This car keeps stalling out after it has been driven 10 or 15 miles. Once you start running errands short distance it will stall out. There are no engine codes it has new spark plugs, fuel filter, and new oil change. Can someone explain what should be check or done next. Thank you for time very much.
Jun 1, 2010 at 4:23 AM
BLACKOP555
  • 10,386 POSTS
does it sputter out? or turns off just like the key was turned off?
when it stalls out can you start it right up and it runs good or do you have to wait. if so how long?
how long does it run between stalls
Jun 2, 2010 at 3:08 AM
