Monday, September 20th, 2010 AT 9:29 AM
3.8 V6 stalls intermittently. No Codes, passes scan tool test. Usually will restart right away but sometimes will be one half hour. Also have 97 Pont. GP same engine. Have swapped coil pack, ignition control module, battery, Fuel regulator. Replaced MAF with new one. Fuel pump tested good. New fuel filter
