2000 Oldsmobile Intrigue car stalls
PAUL P
  • 2000 OLDSMOBILE INTRIGUE
Engine Performance problem
2000 Oldsmobile Intrigue 6 cyl Two Wheel Drive Automatic
my car starts and then stalls sometimes and when I try to start it it seems to act like it is flooded
Friday, November 27th, 2009 AT 8:46 AM
ERNEST CLARK
  • 1,730 POSTS
Is your check engine light on? If so, then that's the first place to start. AutoZone will scan your computer for free.
This could be an ignition or fuel related problem. But to me, it sounds like your fuel pressure regulator is faulty.
If you are so inclined, check system pressure with a fuel gauge. Your system pressure should hold steady at 45-55 PSI with the engine running. (The needle should drop below this) And when you shut your engine off, it should not bleed down.
If the needle drops while your engine is running, then you have a leaking injector or clog somewhere in the system. If the pressure bleeds down after you shut the engine off, then your fuel pressure regulator is leaking.
If I've helped you, please vote for me, as I depend on this to pay my bills.
Sunday, January 24th, 2010 AT 9:18 AM
Related Engine Stall While Driving Content
