Sounds like you need to talk to your mechanic? Are you saying the starter won't even crank? Check the battery and cables, starter circuit.
If it cranks good but won't start, have a helper crank it, while you check for spark at the plugs. Got plenty of spark everywhere, check fuel pressure.
Can you check cranking vacuum or compression?
SPONSORED LINKS
Saturday, April 4th, 2009 AT 1:39 PM
