1998 Oldsmobile Intrigue heater fan.
MIKKA_P07
  • 1998 OLDSMOBILE INTRIGUE
  • 6 CYL
  • FWD
  • 170,000 MILES
Warm air seeps out of my vents but does not blow. It sounds like it should be blowing but does not. It also seeps warm air when I have the heat OFF, or any other setting such as defrost. What could be the cause of this?
Friday, December 11th, 2009 AT 4:52 PM
  • 109,885 POSTS
If the blower motor is working but nothing is coming from the vents, you have a vacuum leak. Check under the dash for vacuum leaks. If the engine is running, you may hear a hissing.
Let me know what you find.
Tuesday, April 13th, 2010 AT 11:43 AM
