1997 Oldsmobile Delta 88 not working right
290,000 MILES • 6 CYL • 2WD • AUTOMATIC
FABE
car stalled,put in new crank sensor,now car running on 4 cylinders,would a crank sensor cause this/middle coil on coil pack not firing,changed it still not firing on middle coil,
changed module still the same help
Oct 24, 2010 at 5:25 AM
JDL
  • 16,098 POSTS
Swap the coil to another position, see if problem follows the coil, if it does, suspect the coil.
I see you replaced the suspect coil. Remove the coil, use a testlite between the ignition module primary terminals, those prongs, have helper crank, if the lite doesn't pulse, I suspect the ignition module. You have spark at the other plugs, correct?
Oct 24, 2010 at 6:58 AM
