1986 Oldsmobile Delta 88 Power Windows
111,352 MILES • 6 CYL • 2WD • AUTOMATIC
ANDY BEAST
mywindows on it rolled down but wont roll back up any ideas?
Apr 12, 2010 at 3:50 AM
  • 110,248 POSTS
Remove the door panel. THere are two wires that go to the window motor. One gets power in the down position, the other in the up. Check if you are getting power when you switch them up. If you are, replace the motor. If there is no power, chances are the switch itself is bad.
Let me know what you find.
Apr 12, 2010 at 2:29 PM
