1994 Oldsmobile Delta 88 sub frame bushing replacement
185,000 MILES • 6 CYL • FWD • AUTOMATIC
SHREK20035
i can access the top nut on the rear bushing, but only the one closest to the engine, the rear one (the are two in the rear) when i try to loosen the rear one i cannot hold the nut from spinning i have asked around and have been told to cut the floor board is that the most professional way? it does not seem likely please advise
Nov 10, 2009 at 10:10 AM
  • 110,244 POSTS
Is it the most professional way? I would say no, but it would work. If you are unable to get a wrench on the bolt to hold it, that may be the only solution. I would most likely drill a large enough hole and then when done, get a rubber plug to fit the hole and seal it.
Apr 13, 2010 at 2:48 PM
