1986 Oldsmobile Delta 88 misses bad
160,000 MILES • 6 CYL • FWD • AUTOMATIC
BSTROCKSINGER
I have checked the fuel presure and it is reading at 20psi at the fuel rail. I have changed the fuel presure regulator, fuel pump, blown out the fuel lines but it still won't go up. It says it's suppost to have between 65-90psi. It misses so bad that the exhaust glows red. and i tried cutting the cat out still can't figure it out yet.
Dec 1, 2009 at 2:47 PM
HMAC300
  • 48,601 POSTS
have a pro look at this hecan fix it faster and cheaper than you could. Itcould be a multitude of things wrong . H'ell have the proper equiptment to diagnose the problem......
Jan 18, 2010 at 5:52 AM
