1987 Oldsmobile Delta 88 too much fuel
1987 OLDSMOBILE DELTA 88
92,000 MILES • 6 CYL • FWD • AUTOMATIC
JSHINKLIN
  • 7 POSTS
we are now at the opposite end of the problem we were at before. we now have TOO MUCH gas going thru the rail, it is flooding itself out. Fuel pressure is PERFECT, but for some reason why to much fuel is going thru and cause the car not to start. The plugs are full of fuel, the injectors OHM out normal at 16. Wondering if we should check the injectors first or replace the ECM again?
Thank You
Sep 17, 2010 at 9:54 AM
WRENCHTECH
  • 20,761 POSTS
What does your fuel pressure do when you shut the key off?
Is the check engine light on?
Sep 17, 2010 at 10:43 AM
JSHINKLIN
  • 7 POSTS
Fuel pressure is normal...and no check engine light on...we are totally lost at what the prb could be
Sep 17, 2010 at 10:59 PM
WRENCHTECH
  • 20,761 POSTS
I didn't ask if the fuel pressure was normal. I asked what it does when it's shut off.
Sep 17, 2010 at 11:27 PM
JSHINKLIN
  • 7 POSTS
what do u mean...when the car is shut off it does nothing...
Sep 17, 2010 at 11:42 PM
WRENCHTECH
  • 20,761 POSTS
Does the pressure hold after the key is shut off or does it drop off?
Sep 17, 2010 at 11:43 PM
JSHINKLIN
  • 7 POSTS
key in on position its at 38 PSI I dont think they checked it with the key off though...
Sep 18, 2010 at 12:23 AM
