1990 Oldsmobile Delta 88
DEEDEE35
  • 1990 OLDSMOBILE DELTA 88
Engine Performance problem
1990 Oldsmobile Delta 88 6 cyl Front Wheel Drive Automatic
sputters after running, idles go from regular to high back to regular and so on, push on the gas and and it cuts off. Already changed fuel filter, checked fuel pump what else could it be
Thursday, May 6th, 2010 AT 10:56 AM
  • 109,867 POSTS
Has the check engine light come on?
Thursday, May 20th, 2010 AT 8:46 AM
DEEDEE35
  • 11 POSTS
Yes check engine light comes on then after a while it goes off
Thursday, May 20th, 2010 AT 11:42 AM
  • 109,867 POSTS
What to do is take the vehicle to a nationally recognized parts stores and have them scan the computer for trouble codes. If the light has been on, there should be a code identifying where the problem is coming from.
Let me know what you find.
Thursday, May 20th, 2010 AT 11:53 AM
