1977 Oldsmobile Delta 88 CRANKS BUT WON'T START
KELLYOLDS
  • 1977 OLDSMOBILE DELTA 88
  • V8
  • 10,500 MILES
I HAVE REPLACED THE FUEL PUMP, FUEL FILTER, ADDED GAS TO THE CARBUERATOR AND IT WILL RUN FOR A FEW MOMENTS AND THEN DIES. CANNOT FIGURE OUT WHAT MAY BE THE PROBLEM.
Saturday, January 10th, 2009 AT 2:26 PM
Do you hear the fuel pump when key at run for a few secs-confirm the fuel pressure if its within specs and also if the injector/s are pulsing and also test the oil pressure sending unit
Saturday, January 10th, 2009 AT 3:59 PM
DOCFIXIT
  • 18,828 POSTS
Probable stuck float or seat not letting fuel into bowl. Also could be debris in cabr. Reccomend a rebuild
Saturday, January 10th, 2009 AT 4:11 PM
Check the choke plate if its opening and the fast idle cam adjustment
Saturday, January 10th, 2009 AT 5:40 PM
