ac/heat fan stopped working totally, but before that the typical prob , settings 1,2, not working on fan switch. settings 3,4,5 ok, blew constant never automatically slowed to lower setting. Replaced resistor. Fan did not work. cleaned blower fan relay pins, fan then worked on 1,2,3,4,5. for a day or two( Think)..then fan would work ok when car starts up from cold, switch put on #5 setting. Blows strong, but slows down by its self to almost nothing over a 5 minute period. once when driving I jammed the bakes on and the fan stared going faster for a minute, then slowed down, once I turned a corner fast and the fan ran faster again, then slowed down. the new resistor i put in last week was made my BTD, and I was assured it was the right one. what the heck is going on? I swapped out the blower relay in the engine compartment with one next to it that was the same..no difference in problem of fan slowing down by its self. ..can a relay cause this? will gladly send you 15 bucks if your advice cures the problem..it is too expensive for me to just replace parts til I find the prob. and going to a repair shop..please.. I am still sore from being reamed last time
Aug 18, 2010 at 6:31 AM
