1993 Oldsmobile Cutlass Fan does not work
1993 OLDSMOBILE CUTLASS
SWISHERS5
Heater problem
1993 Oldsmobile Cutlass 6 cyl 95000 miles
My son has a 93 Olds Cutlass Supreme and the blower does not work. I checked the fuses and they are fine. What could the problem be? I have tried researching this and I have read it may be the blower motor, blower motor relay or speed control resistor. So where are each of these located? And how to I test them to see which one it might be? Thanks for all your help!
Aug 27, 2009 at 6:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first thing to check is the relay, since it is the easiest and cheapest component. you can learn how to test a relay by following this link..
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
your vehicle's blower motor relay is located in the component center, behind right side of instrument panel.
Aug 27, 2009 at 7:28 AM
