1988 Oldsmobile Cutlass blower motor
CATHIE STRICKLAND
  • 1988 OLDSMOBILE CUTLASS
Heater problem
1988 Oldsmobile Cutlass Wheel Drive Type unknown Automatic 950000 miles
I have purchased a replacement motor for the blower and can't get the old one out. The alternator is in the way. Is there a trick to the removal or do I need to remove the alternator.
Sunday, January 13th, 2008 AT 7:21 PM
BMRFIXIT
  • 19,053 POSTS
Can you disconnect the front motor mounts by the radiator and pull it forward and try that way it will be a bit tight but you should be able to clear it
Sunday, January 13th, 2008 AT 7:48 PM
