1997 Oldsmobile Cutlass starting problems
PISTONMANIA3
  • 1997 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 144,000 MILES
When I go to start my car, it will fire up. Then after a few seconds. The idle will drop and then choke out. Causing the engine to shake very hard. Other times it will start up just fine. The idle will continue to work. Then, when I put the car in gear, it will once again drop in rpm's and choke out. What could this be?
Saturday, October 31st, 2009 AT 12:34 PM
  • 109,867 POSTS
Has the check engine light come on? Have you checked fuel pump pressure? Have you checked for vacuum leaks?
Here is the process for checking fuel pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Wednesday, November 18th, 2009 AT 11:23 AM
