1996 Oldsmobile Cutlass
SILLYC2
  • 1996 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 74,000 MILES
Engine sluggish only when hot. No codes setting. Lost 8 mpg. Replaced temp. Sensor and pcv valae
Sunday, April 18th, 2010 AT 6:28 PM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Sunday, April 25th, 2010 AT 4:50 AM
SILLYC2
  • 5 POSTS
Oxygen sensor was the problem thank you
Tuesday, May 4th, 2010 AT 5:29 PM
