1994 Oldsmobile Cutlass gas valve on engine
MANNY9876543210
  • 1994 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 145,026 MILES
The gas valve on my 1994 cutlass remains open at all times causing for the chambers to over flow. Changed out the valve already thinking it was that but the problem remians.
Tuesday, November 3rd, 2009 AT 8:52 PM
  • 109,747 POSTS
I'm not sure what a "Gas Valve" is. Are you refering to the fuel pressure regulator?
Wednesday, November 18th, 2009 AT 11:16 AM
  • 109,747 POSTS
Sorry, I hit reply by accident. Have you checked the fuel pump pressure? Here is a how to for checking:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
I would recommend checking that. Let me know what you find.
Wednesday, November 18th, 2009 AT 11:17 AM
