1983 Oldsmobile Cutlass fuel hand
CUTLASSTEDDY
  • 1983 OLDSMOBILE CUTLASS
Other Category problem
1983 Oldsmobile Cutlass Engine Size unknown Wheel Drive Type unknown Automatic 75000 miles
I have a 1983 cutlass supreme and the gas hand isnt working properly. The hand says the car is full even when its empty. What should I do?
Saturday, February 2nd, 2008 AT 5:38 PM
SERVICE WRITER
  • 9,123 POSTS
Probably a problem with the fuel sending unit. The tank may need to be dropped. There is a reostat on the sending unit that may have worn windings on it.
If you don't want to go through the expense, fill the tank, record you milage. Multiply the gallons used by 10 and when you reach that point put more gas in and see how many gallons you still had to see how much further you may be able to go in the future.
Saturday, February 2nd, 2008 AT 6:00 PM
